Which Methd Used To Access Files To Other Computer Remote Connection
I want to Access Files on another Computer without the use of Remote Computing. Is there any other method that I can use to perform this process?
Yes, you can use another method to access files on another computer. NAS Devices and Routers allow you to do that without Remote Computing. NAS is the short form for Network Attached Storage.
NAS Devices have dedicated support to access your files on the Internet. This method is sometimes insecure because they are designed to work on secure local networks only.
Routers also have USB ports that allow you to connect your hard drive to it and access your files on another computer on the local network.
Notifications
