Which Method Used For Microsoft Access Database Mac OS X.
Asked By 230 points N/A Posted on -
I have an Apple MacBook Air MMGF2HN/A that runs Mac OS X on it. Being a Database Administrator, I have been using MS Access all the way. Is there any method to run MS Access Database Mac OS X?
Answered By 0 points N/A #126893
That is a good question which comes to many people’s mind. Can Microsoft’s products be used on Apple’s MacBook? The answer is yes. I have listed some apps that allow you to run MS Access on Mac OS X.
1) You can use MDB tool that can provide access to the tables. But, it does not support queries, forms, and reports. This app is available for 3.99 Euros.
2) Another app is MDB Explorer that can open tables from more than two Databases at the same time. It costs 2.99 Euros.
3) You can use MDBLite to convert MDB to SQLite by just dragging and dropping MDB file onto the app’s window. It is available for 1.49 Euros from Apple Store.
4) ACCDB Explorer is similar to MDB Explorer that supports ACCDB as well as MDB files. It can open Access 2010 files for 13.49 Euros.
