Which is much better to do?
What if your personal computer had a virus named Trojan?
One of the Computer Technician says it's okay to just clean it up. Which is more ideal to do, to clean up the drive?
or to reformat your computer? .
Best ideal you should do is to reformat your computer to make your disk 100% clean.
Cleaning up the drive is not advisable because it is not 100% cleaning up the folder containing the Trojan.
Trojan is a traitor virus. You must deal with it seriously.
Reformat your computer, setup a latest Operating System and load an updated antivirus. I suggest Windows 7 Operating System.
Thank You.
Hi Dyl 24,
In order you to decide of which was the best solution, I'll site the advantage and disadvantage.
Option 1
Install anti-virus on your PC. Nowadays, there are lot of anti-virus software you only have to do is to choose the best among all the anti-virus scanner. Once it you download, you run the anti-virus software wait for a second and then on the screen of you PC will appear information with regard on the treat level of the scanned files or program. Restart your computer and you find out that there is some virus again fix it by re scanning the anti-virus again. Once, the anti-virus scanner fix the problem your files remain on your PC.
Option 2
Reformatting of your PC was the worsen thing you will do when there is a virus on your PC. This means that there is a large option on your files that are infected by Trojan virus. Before you reformat your PC you must have a back-up of all your files because once it was reformat all your files will deleted or wiped out.
The best solution was to try to install a best anti-virus scanner before you reformat your computer. Hope I can help you through this a simple advice.
“Trojan” is not a virus name but the type of virus that infected your computer. The technician’s suggestion is ok. It’s fine to just clean or remove the virus from your computer instead of reformatting your hard drive. Reformatting the hard drive will mean lots of work because you have to install the Microsoft Windows operating system and all the applications currently installed on your computer.
To remove the virus from your computer, you can download Sophos Virus Removal Tool. It works alongside any antivirus program you may have so that means, you don’t need to disable or uninstall your current antivirus to use Sophos. Once Sophos is installed, start Sophos then wait until the virus signature database gets updated. Once update is complete, click to start scanning your computer.
It will scan everything on your computer including external devices connected via USB port like USB flash drive and USB external hard drive. When a virus is found at the end of the scan, remove the virus then repeat the scan over and over until it no longer detects a virus. See if this works.
