Which nokia lumia should i get for better display
I am interested in the new Lumia Nokia phones the 600 and 800. But I was wondering which would be best for me since I get a lot of emails and attachments and the phone I have right now doesn't help me.
Which is the best for my purpose?
Best Answer by Carl Jack
Answered By 10 points N/A #162056
Hallo Quiqui,
Nokia Lumia 900 is the best of the Lumia phones. Some of the best features you will like about it are:
  • A classic body frame that is made from polycarbonate.
  • It has been made using a clear black technology that makes it possible for the 4.3 inch screen to be used outside even if one has got polarized glasses on at any angle.
  • Its corning Gorilla glass ensures protection of a very clear AMOLED display.
  • When it comes to storage, the Nokia Lumia 900 has a 16 GB storage size that will allow you to save very many data on it. It also allows expansion in case you need to use more than 16 GB.
Carl
Answered By 0 points N/A #162057
I think you should buy Lumia Nokia 800 as it is fit for better networking also its screen display is nice and standard.
Answered By 5 points N/A #162059
Nokia Lumia 600 is working on Symbian Belle OS with CPU 1 GHz processor. It has lots of features that offer 2G and 3G network. Its dimension is 111x53x13mm and weighted only 100 gm.
It also has 3.2 inch wide TFT capacitive touch screen with extra Multi-Touch features. The internal memory is 2 GB expandable to 32 GB Micro SD so it can surely handle attachments in your email. It also offers limitless phonebook contacts with Photocall. The camera is 5 MP with 2592×1944 pixels.
Nokia Lumia 600
Nokia Lumia 800 is a Meego-based Smartphone with screen size decreased from 3.9 to 3.7 inches. The processor is upgraded from 1 GHz ARM Cortex-A8 to 1.4GHz MSM8255 Scorpion/Snapdragon that will surely support Windows Phone Mango 7.5 OS. Its Internal memory is 16 GB but it doesn't have a card slot. The camera is 8 MP 3264×2448 pixels.
Nokia Lumia 800
