Which anti various applications is good? I am using avast free antivirus. Someone says its protection is not good because everyone uses it. So they say bring variation to protect your PC. Is it right? Please suggest me.
Which one is the best free anti various application for download?
Hi Mantos,
I believe I can be able to help you solve this query in the best way possible. There are several antivirus applications, some of which are free, others need you to buy the activation key, meaning the only free version you can use of them is the trial version! In my opinion, I would advise for Kaspersky as the best anti-virus.
This is because it offers maximum protection against anti-viruses, providing even security even for applications from threats.
It offers full computer security and safety against Operating Systems as well as internet explorer intrusions, key-loggers, adware, dialers, and harmful pieces of software.
It is very effective in that it is one of the most reliable safety software and also it is among the very first to discover the modern viruses.
The program updates on routine intervals and also offer prompts in the same. You can also have the option of upgrading manually. Its updates are also not too big to add.
It is also very easy to set up, you can either buy from your nearest local computer shop or even from an online source.
This should solve your query.
Hello Mantos,
In my experience Avast Antivirus is a good software / freeware to use. It does protect your system from many malicious viruses. If you are not satisfied with your antivirus, you might want to try one of these popular antivirus:
1-Â Norton Antivirus
2- Avira Antivirus
3-Â AVG Antivirus
4- Kaspersky Antivirus
The pick of the Anti viruses among the list is Avira antivirus, because it is a light weight software which does not slow your PC down and gives you the total protection from many different viruses.
