I have a Joomla site and want to move to another hosting server. So I am searching an easy method for it. I come to know that Joomla pack can help me in this regard but I want to know the best one. Do you have a recommendation? I will be glad if you please add the guideline too.
Which one is the best joomla pack application?
Hi Alber Sontie,
I have to do lots of work for it. 1st you have to make a mirror copy of your website by using any FTP software like as filezilla or cuteftp. Then you need to export your all database as a gz extension from the cpanel phpmyadmin. After transferring and installing your new server then again you need to import your all data, in cpanel.
Thanks for asking.
