Which one is the best m4v decrypter from Blu-ray?
Hey I am a user of Apple I phone User. I cant see the blu-ray movie on my mobile how can i convert the movie into m4v format. which one is the best converter.
Hi Laurel Shifflett,
I understand your problem and i'd be glad to help. You can't play blu-ray movies to your iphone because the phone doesn't support the format of the video you want to watch. You have to convert the video to mp4 format so that you will be able to watch.Â
Here is a link of a free video converter:
http://www.pcfreetime.com/
Hello Mr. Laurel,
There are some good tools available to convert Blu-Ray movies into the iPhone's M4V format.
Try these free software's :
RipBot264 All-In-One Converter: A very good all in one converter to convert Blu-Ray, DVD or any other videos into various formats for iPad, iPod, XBOX360, PS3, PSP, MKV etc.
Videora iPhone Convereter : A free dedicated iPhone converter to convert movies, videos, YouTube videos into the M4V format to play them on iPhone.
Click here to learn how to convert your Blu-Ray files into iPhone by using RipBot264 or Videora.
Hope this helps.
Best regards.
As an enhanced version of DVD, Blu-ray is way better regarding video and audio quality. So when you attempt to rip Blu-ray to M4V, it’s important to keep the quality loss to a minimum, or there will be no point in getting a Blu-ray disc for a movie.
For a high quality Blu-ray to M4V converter, check out Leawo Blu-ray Ripper. What makes it a top-notch Blu-ray ripper is that it can rip Blu-ray to lossless MKV video. And there’s a lot more things it can do. MP4/M4V is one of the 180+ formats it supports ripping Blu-rays into.
If you want to konw more, you can browse the link:https://www.leawo.org/tutorial/blu-ray-to-m4v-1334.html
