Which one is better Norton or AVG antivirus?
What is the best antivirus in the market now? I am choosing between Norton and AVG. Which among the two is suitable for my personal computer?
First of all, let me clarify one thing. No antivirus is perfect. Every system is vulnerable to viruses. So, there is no anti-virus solution which can be called ideally best. But relatively speaking, AVG is the best antivirus among the both. AVG uses comparatively less resources and provides more protection.
The online features are also very well developed and utilities like link scanner are truly useful when browsing the internet. Make sure you buy AVG Internet security package, don't just use the free version if you truly want to protect your pc. In my personal opinion, Kaspersky is the best.
Sandeep
If you want to protect your computer from virus than Avg is best for your computer
Avg antivirus is best of the world at this time because it is simple to use and not make the computer slow and on the other hand Norton antivirus is so slow and difficult to use and make the computer so slow.
Avg antivirus has so many advantages on the Norton antivirus like:
1:specially in the area of games and YouTube and software Avg protect computer greatly from virus.
In ranking, AVG comes first before Norton in terms of protection. basically the AVG uses the layer type of protection which the Norton antivirus lacks. The other thing about AVG is that it does not intrude unnecessarily it is always watching in an idle mode, it also maintains a database for known threats so you can be well protected in future if they try to crawl back.
Antivirus is required to clean and repair the infected files, and also to provide the compatibility in terms of security for other programs like Internet explorer security settings as well as the update with the newly coming viruses. Norton Antivirus is unable to clean many new viruses. In terms of memory consumption, Norton is occupying more than AVG. One of the most important thing is that the AVG is more economically feasible and fast while Norton slows down the computer while taking many resources, misses viruses in addition it ends up blocking all secure sites and some programs. AVG is better than Norton after considering all these points.
