Dear All
I have recently visited a website and read about Files Connect. It is an application through which we can share, print and stream files. I want to know Operating System it supports. Please provide me the detailed Files Connect review.
Which Operaing Systems are supported by Files Connect
Hello ,
If you are planning to download Files Connect, make sure to check first the following system requirements:For Mac users (Files connect version 1.2.0.2) – it requires Mac OSX 10.5 or later.For Windows users (Files connect version 1.0.1.2) – it requires Win XP or later.
You can download this awesome software at https://www.acronis.com/en-in/mobility/mac-windows-compatibility/.
I hope this answers your question.Â
Hi Well,
File connect is a file sharing systems for both Mac and PC and offer you to host, connect and share with computer on your network. Its most important feature is the ability to set up the iPhone as a wireless network drive.
Literally no configuration is required (But you can), if the application is running and you're on the same home network, your PC or Mac can connect to transfer your files. You can turn your device into a file server.
It also supports Bonjour, it is also speedy. You can use printer too. Not only iOS native printing but also CUPS printers too.
The app can be used with Windows, Linux or Mac simply and easily. For more detail review, please check the link
