What is PovRay? On which paper is PovEdge useable? What is PoseRay? How do I get a cel-shading to have equal texture? When I use toon gradation textures with low genius, I get rum shadows (the borders of the shadows are toothed)?
On which paper is PovEdge usable
Hello Phillip Mcmayo,
PovRay refers to Persistence of Vision Raytracer in full, and it is a tool that is used to creating three dimensional graphics ands it is available to be used on all operating systems.
As for the paper that is suitable for PovEdge, I think a drawing paper will be good.
PoseRay on the other hand is a utility that is used for converting 3D model meshes into POV-Ray scenes, Moray UDO files or Kerkythea meshes depending on which mode that you may want them. Another function that poseray can perform is editing materials and can also be used for simple transformation in geometry, and also exporting models that have been modified to wave font format so that they can be used in some other 3D programs.
__
Regards
Clair Charles
