Which procedure can eliminate Prototype 2 error text solve?
I installed a new software on my PC recently, this has caused system instability and always reporting an error.
How can I eliminate prototype 2 error text solve from the pc?
Can this end the error reporting and instability?
Best Answer by Johnstoon Leen
Answered By 0 points N/A #147366
I may suggest to you to use a cleaner for you arrange properly the application you been installed or else if you are not interested to the application that you installed you may uninstalled it to your computer if in case the problem still there you may go reformat your desktop.
Answered By 0 points N/A #194890
Hi Acke Zimri
There can me multiple cause of getting this problem.
Well to get rid of this problem just check the compatibility of your software requirements with your system specifications.
It is most important for you that you should have DIRECT X latest version.
You must check that your graphic card driver for prototype 2 is installed or not.
If you are using window 7 or vista you must have to disable UAC.
Install the latest updates for your OS which is a good step from where you might resolve some issues.
You must also check the sound card driver for prototype is installed or not.
These are the main things which can cause these types of problems.
Here we have multiple solutions.
Solution 1
You must try to run your app in lower resolution.
Solution 2
You should delete all the temporary files from your system by doing this.
Click on start menu then click on Run, now type %temp% click OK, click edit and then select all then delete.
Solution 3
Disable your antivirus program and make sure to re enable it after using your app/software.
Solution 4
You have to disable all unimportant background applications before start your app.
Follow these steps to terminate your unimportant applications.
Got to start and click on RUN.
Type “msconfig” and click the startup tabs now click disable all buttons, click apply and then OK.
Restart your Computer now.
Well these solutions will really help you to get rid of this problem. I hope you’ll enjoy these tips. Good Luck!
Johnstoon Leen
Answered By 50 points N/A #147367
Thanks, my friends, for your information. Johnstoon Leen: your solution is all helpful.
Among those solutions, I prefer the first one because it seems easy to me.
I am using Windows 7 so in accordance with your instructions I have disabled UAC. Then I installed the latest updates, and also checked the sound driver for Prototype and I found that my graphic card driver for Prototype 2 is installed.
As a result I saw that my problem has gone so now I am not facing any problem. Superb, guys.
Thanks again.
