Which Product Should Be Installed Microsoft Office Windows 8.1
I want to install Microsoft Office in my Windows 8.1, and I don’t know which version I should choose. I want to know which Microsoft Office Windows 8.1 would be better.
If you have Windows 8.1 then you should go to Microsoft Office 2013. Windows 8.1 uses Microsoft Outlook to sync your data, and hence, you should opt for the Microsoft office which also gets sync with Microsoft Outlook.
Microsoft Office 2013, 2016 and 365 are the best suited for this purpose. All these products use Microsoft Outlook to sync your data and hence you can always view, edit and share your data with the help of Microsoft Outlook. So, Microsoft Office Windows 8.1 should be 2013, 365 and 2016 version.
If you have Microsoft Windows 8.1 and wondering which version of Microsoft Office is compatible with your platform, you can install Microsoft Office 2007 and higher. This means on your Windows 8.1, you can install any of the following versions of the Microsoft Office suite:
The following versions are not compatible with Windows 8.1:
Microsoft Office is a series of client applications, server software, and services developed by Microsoft. It was originally announced by Bill Gates at COMDEX in Las Vegas on August 1, 1988. The initial release of Microsoft Office includes three applications only: Microsoft Office Word, Microsoft Office Excel, and Microsoft Office PowerPoint. Softpedia reported on July 10, 2012 that Microsoft Office is used by more than one billion people worldwide.
Notifications
