To whom it may concern,
Good day everyone!
I just wanted to ask in which site can I download Logitech webcam driver for free.Â
I need it to enhance my current webcam in my desktop.
Thank you!
In which site can I download Logitech webcam driver for free?
Hi Chloe, you can download your driver on the Logitech website. Visit and follow these steps:
1. When you enter the website chose your location, then you will enter in the home page.
2. Go to products – Webcams and Headsets – Webcams.
3. Choose your webcam model and the platform of your computer (MAC or windows). Click on your webcam's picture to display on its features, gallery, specifications, reviews, support.
(Click on your product model)
4. Click on Support.
5. Go to downloads. You can then see your webcam description, why you should update, and the download instructions.
6. Click on the blue button named Download software on the lower left side and wait for the driver to download.
7. After you download the driver. Install the driver for it to work.
Hope this will help you out. This driver is for free.
If you need to install the driver for your Logitech webcam, try downloading this Logitech Webcam Software. Just select your correct operating system from the dropdown list and download the installer. The driver is available for Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. Alternatively, you can use ManyCam. It works for any webcam as long as your operating system is supported.
It supports Windows 7, Windows 8.1, and Windows 10 and requires Intel Core i3 or faster processor, 2 GB RAM, and internet connection for subscription activation.
