William Sao
30 points
Posted on - 12/13/2012
I know that skype had an extra option before to play games, personalizing your account, etc. but when I downloaded the latest version it was gone. which skype version have extras option? and provide a link if possible
Which Skype version have extras option/manager?
You can solve this by uninstalling your Skype and reinstalling it again. During installation, make sure to check the Install Extras Manager box so that the games will be installed too.
If ever you don’t want to do that, you can download Skype games at this website http://www.gamexn.com/. Don’t worry since the site is in partnership with Skype which is why all the games are made for Skype. Don’t worry about compatibility issues.
Hi William Sao,
The Extras section that had the Games link has been removed in the new version of Skype. To play games, please download the old version of Skype from https://skype.en.uptodown.com/windows/old
Here you will get many versions of Skype but you can select Skype version 4.0.0.161
This version lacks some of the features of the latest version so you may prefer to use the latest version and just download Skype games to use on the version you have.
