Which Software Can Be Used to Compress Files?
10 points
Posted on - 11/14/2014
When you want to compress files, which software have you found to be quite good at doing the job? What criteria are required for compressing files into smaller sizes? Which file formats are ideal candidates to consider for compression? Does compression result in some issue with regards to data corruption?
