Which software can produce glass beach home design?
I need software which can design a high class structure. Can I get design software which will produce a good glass beach home design with timely delivery assurance? Help
You can try the Autodesk® Revit® software. This software is used by structural engineers and designers. It has tools that produce more efficient building structure and more accurate design. Prior to construction, this software predict the design’s performance. It has also simulators and analysis. You can choose between Autodesk Revit 2013, or Autodesk Revit Structure 2013.
Hello Maxine A Fenster,
You can use AutoCAD. Architects, project managers and engineers use this software for their designs and their 3D structures. You can not only design the outside looks but also on the inside with precise accuracy in measurement. You can also put the furnitures like chairs, tables etc.
Hope this helps.
