Which software helps me create a website design?
Hello Khaled_mithun,
There's a lot of software used in building websites. I use Adobe Dreamweaver CS4. It's very easy and I'm sure you can make a beautiful website using it.
Also, I recommend Adobe Photoshop CS4 or CS5 for your website images.
I hope this helps you build your own website. 🙂
HTML is used to design websites. Once you know HTML, you can design any website yourself.
You can also use a template of a website as a starting point. Microsoft Front page, which comes with office, can be used to design a website or to edit it from a template.
Another solution is to use a Website that allows customers to design their own websites online using online data sources and templates. All types of websites can be designed.
I hope this helps you create your website.
There is a Techyv article which one will be helpful for too. Pay a visit that article and get idea about the software that can be you used to create your website.
