Which software remover is best for removing installed applications?
Hi! I installed a third party system utility into my windows machine but it has refused to work, or maybe I don't know how to use it. I went into my control panel to uninstall it but could not find it among the programs list. I need a software remover that I can use to completely uninstall the program, delete all its folders and to remove all its information from the registry. Kindly let it be windows 7 compatible. Why is the program not showing in the control panel? Thanks.
Answered By 30 points N/A #199417
Thanks for sharing your problem with us.
There are many ways to remove any installed applications.
Simply click on start button and go to all programs. Here see your installed program, click on it, it will open the application launcher icon and an uninstall icon.
Click on Uninstall. It will remove the software from your computer.
If you want to use application to remove software from your computer. Then i have a best software for you.
You should use Revo Uninstaller in this regard. It is compatible with windows 7.
You can download it from this link.
Revo Uninstaller Download for Windows.
Thanks
