I use windows 7 64 bit and want to use tomcat.
Which version of tomcat will be better for my operating system?
From where can I download the exe file? Is there any compliancy in installation?
If yes, describe in a nutshell.
Thanks
Which tomcat exe is better for windows 7 64 bit?
The latest version of Apache tomcat will run fine with windows 7 64bit ot 32 bit. The latest version at present is version 7.0.36, but his will get updated you don't have to worry about the version any latest version should run. You can download the .exe installer from here  http://tomcat.apache.org/download-70.cgi . The installation is not complex at all it is a straight forward install.
Peter franklin
When you use any web application servers such as Apache, Apache tomcat or warm-up you should select the upgrading versions every time you need it because of the new features which the new version has okay? Now you asked about the suitable version of tomcat for your windows 64 bit, the appropriate version is 7.0.39
And you can download it from https://www.windows7download.com/win7-apache-tomcat-x64/download-wmzddhkl.html
