In which tool to play cda file in cellphone
I am trying to play cda file in cellphone the various multimedia players are not supported .cda file extension. Will you please tell me that how to play cda file in cellphone? Is there any application or tool to run on it?
Best Answer by Barbara Miller
Answered By 0 points N/A #195568
Hello Azreil Balthazar,
A .cda file extension is not an actual audio file, it is just a link to a file that is on a CD, it does not contain any other audio information. So in order to play .cda files you will have to Rip them from the CD and then transfer it to your cell phone. When you enter a CD into the ROM, a window pops up, asking if you want to Rip the CD or listen to it. Rip the CD using Media Player and then transfer it to your cell phone via USB Cable.
Answered By 5 points N/A #195588
Hi Azreil,
Since a CDA (Compact disc audio track) file is among many audio formats which can be played with the help of a software, although by default it’s not by default supported by many media players. However there is an alternate way to play this file.
Download the software while clicking on the link below and convert your .Cda audio file into your desired format of your cell phone like mp3 or .wav or other.
https://www.coolutils.com/Formats/CDA
Hope this helps.
Thanks
Baker
Answered By 0 points N/A #195591
Hello Balthezar,
You cannot play cda extension file into your cell phone, because cda file is not an audio file. You will be able to play it on your cell phone if you convert cda file into MP3 file. It is also possible if you convert it into a Windows Media file. To convert your cda file into MP3 file for free, you can visit this link and follow their recommendation
http://www.freerip.com/frmmanual/tutorials/how_to_convert_cda_files_to_mp3.php
