Which Tools Can Be Considered As The Top 10 IP Scanner Software?
I am getting interested in Cyber Security and Ethical Hacking. I recently came across Nmap. I would like to know about the top 10 IP scanner software to learn more about them.
Different websites will give you different top 10 IP scanner software. I will list them according to my preference and why I like them.
1. SolarWinds
It provides a real-time analyzer and can detect network devices automatically.
2. Paessler
It provides multiple interfaces and multiple locations scanning.
3. IntruderÂ
It provides information about threats to your device as well as their remedies.
4. Thousandeyes
It provides an excellent integration facility within your existing system and can check diverse networks.
5. Qualys
It helps you to efficiently manage cloud networks.
6. Wireshark
It is an open-source tool to efficiently detect vulnerabilities in an active network.
A free and open-source tool to perform multi-thread scanning.
8. SoftPerfect Network Scanner
You would use this in a multi-protocol environment.
9. Nessus
A top vulnerability scanner with 70000+ plug-ins and services.
10. Fiddler
A good tool to play with HTTP traffic.
