I am currently using Linux OEM Edition but I cannot play music files on this OS. How can I enable this Feature on my Linux? What are the other versions or editions of Linux? Which is better to use? I need ideas please.
Thank you.
lee hung
75 points
Which version of Linux is better to use?
Hello Violet Powell,
May be you are required to install the music player manually on that version of Linux in case it does not come with it. I will advise that you review the manual and check for the players that come with that version, and also check on how to locate them and use them. The music player may be there but you may be having trouble on how to use it.
Otherwise, if you may need to consider other versions Linux, I will suggest that you try the Linux open suse version. This distribution comes with both a music player application and video player embedded, and therefore you will not need to go through the trouble of installing it again.
Hope this helps.
__
Regards
Lee Hung
