jalava45
Posted on - 12/15/2011
Yes, I have an old RivaTuner v2.0. I got this error message below when I tried to use it on a new NVIDIA card.
Anyway, my question is; which version should I get?
Where could I get the right version for my card?
Please guide me.
Unsupported driver detected
Warning! RivaTuner has not been tested with the currently installed display driver.
It is strongly recommended to upgrade RivaTuner to a new version. Otherwise it may not work properly because the driver is not officially supported
Don’t show this warning till installing new unsupported driver
Which version of Riva Tuner to get for a new NVIDIA card
The latest version of Riva Tuner is 2.24. It has all the update & support of NVIDIA graphics card. It will surely support your Nvidia Card. You can download the program from the link.
You may also have to download the Nvidia Graphics Cards latest version driver. You can download the updated Nvidia Driver from nvidia.com>USA/Canada>driver download.
From this site, you can download your windows supported latest/last updated Graphics driver. Together with the latest driver, the Riva Tuner v2.24 will work smoothly in your PC.
You can enjoy any games or graphics work without any problem.
Regards
Crawly Math
You need to visit the website of the company your card is build of. The best solution is available on that website.
You need to check that website and then download the drivers for your device.
You also need to update your drivers from that website. As the message shows that your driver is either not supported by the hardware or if you are using this as the software for your drive then this may cause some problem for that.
To check you sound and its quality you can also follow these steps.
Go to START and then to RUN.
Once you are i RUN window then you need to type DXDIAG and then press enter.
Once you have the DX window you need to go to sound and music tabs.
Here perform all the tests for your sound and make sure that you have no problem in your hardware.
If you are not able to see any option available then you need to check your sound card and re install the drivers.
I hope you will be able to solve your problem.
