Which way can we adopt to use equation to flash document?
I need to copy or use equation to perform fairly to flash document, now how to copy equation to flash document?
Hello Jerry,
I have read your concern regarding equation attachment to Microsoft Word. As what I’ve understood with your question, you wanted to insert an equation on the word document but you don’t know how it works to make it more presentable. Is it right?
I think the best way for you to make it more presentable with no hassle at all is to create each equation and save it as an image and insert it in word document. Image can be done through paint, Photoshop, or any program that you are comfortable using with.
You may also perform it by creating the equation manually then press “prt sc” on your keyboard then go to paint and “paste.” From there, you can crop the image until it is appropriately presented. You may now click “File” then select “save as.” From the drop down menu, you can select what image file you would like to save but the best thing to do is to save it as “jpeg.”
I hope I am in the right track of understanding your concern and gave you a hand to fix the problem. I hope this information is of good help.
Good Luck!
Mali
