While Activating AUTOCAD, The Computer Gives An 800c0005 Error
Examine the 800c0005 error? Describe the steps to resolve the error code and explain the cause of this error message?
Error code 800c0005, commonly known as AutoCAD Error and error message displays: AutoCAD has encountered a problem and needs to close. We are sorry for the inconvenience. This error occurs when running the AutoCAD application fails or crashes. The incompatible programs, Viruses, bad graphics drivers are the necessary reasons for the occurrence of the error. The solutions to fix the occurrence of the error are as follows:
Solution 1:
Reinstall the AutoCAD software.
Go to the Start menu and open Control Panel. Now, open Uninstall a Program, then uninstall the software and download the latest application and install it again.
Solution 2:
Perform the clean scan to clear the junk from the system.
Solution 3:
Update the driver of the computer.
