Jamin Ywain
60 points
Posted on - 09/26/2012
While activating WordPerfect Office Xp I received the error message.
It has failed to load some files.
If you have any idea regarding those files please help me.
Third Party Handler Error
Unable to load: f:CorelWordPerfect OfficeX6ProgramsdocumentManagementHandler.dll
While activating WordPerfect OfficeX6 I received the error message
Hi Dear,
Thanks for sharing your problem here.
Dear in this situation you do not have need to go into registry.
Simply check that the third party product which you have installed is compatible with your Corel version?
And installed properly?
Is there any file system error? May be. Because some times bad cluster can make such problems. But you do not have need to worry about it. Simply run Check Disk Utility. If the problem remains same then reinstall your third party software and beware that the installation package should be accurate and having proper files to be installed.
Thanks
