When I change the theme of my WordPress site with a new theme old information on my site appears to be in disarray. How can I maintain the same layout as previous with the new theme as well. Please somebody give me some solution for this problem.
While choosing new theme old information is not displayed properly. Why?
Hello Tracey,
The themes you have downloaded and applied has different CSS styles than one that you previously had. If you downloaded a Free theme from the web, that theme could be poorly constructed.
I am not really using Word press, I am more on Drupal and Joomla software, but this Solution can help you with this problem because I believe this Content Management Tools has the same purpose.
If you have PHP, CSS and HTM skill, you should be able to locate the SOURCE code by opening your Word Press software tool and tweak it there. This is very sensitive, you must not edit the original file, instead copy the Sites Root files and put it on your Computer system. Because this technique requires trial and error even experts can make such mess.
If you don't have those Programming Languages with you, revert back to your previous theme.
Otherwise try contacting Web Master experts to do the trick.
Hope this helps you.
