While compressing a file in FCP 7 I received an error message
Hi guys,
While compressing a file in FCP 7 I received an error message. Initially it was compressing well and the moment likely to be finished, I received the error message. It says, "Failed: Quicktime Error: 0". I do not find any reason behind the issue. Have you any idea?
Please help.
Answered By 5 points N/A #134680
Do you export quicktime from FCP? Or are you exporting from FCP with the use of compressor? Try to export a quicktime and not using export, just a quicktime icon then import that file into compressor. Because missing mpeg2 component into Quicktime is the cause of the error but when a compressor hit the mpeg it has no error occurred.
Hope it will help you.
