Copy grove gives error with a restart
I am trying to copy my workspace but with contents only users and no passwords and it always gives me error and Groove 2007 starts again. Thanks in advance. Help me to solve.
Well here is the solution. Most probably you see this problem because of some DLL files corrupted when you tried to install or uninstall. I gave you the steps. So follow it. I hope your problem will be solved.
If you want to copy a workspace in Microsoft Office Groove that means you will be duplicating a workspace. In Microsoft Office Groove, when you duplicate a workspace, you will be creating an exact copy of the original workspace but the duplicated copy will remove other members except you.
This means after creating a duplicate of the Office Groove workspace, it will only retain you as a member and all other members are removed. To duplicate a workspace, right-click on the workspace you want to duplicate in the Launchbar then click Duplicate Workspace. Specify a name for the workspace and click OK.
SharePoint Workspace then builds a copy of the workspace and then displays its title in the Launchbar. This method applies to Microsoft SharePoint Workspace 2010. On the other hand, if you want to create a backup of your current workspace in Office Groove 2007, the procedure is almost similar to the previous steps.
In Office Groove 2007, right-click on a workspace you want to create a backup to in any list of your workspaces, click Save As, and select Archive. When you are asked for a file name, enter the file name and press Enter.
