While creating database with Microsoft SQL Server I have faced this problem. I have no idea about this exception. If you have any idea regarding this issue please help me.
Microsoft SQL Server Management Studio
Create failed for Database 'myDB'. (Microsoft.SqlServer.Smo)
Additional information:
An exception occurred while executing a transact-SQL statement or batch.
(microsoft.SqlServer.ConnectionInfo)
CREATE DATABASE permission denied in database 'master'. (Microsoft SQL Server, Error: 262)
You cannot create a table on the master database because the master database holds all the configurations and security settings of your SQL Program, you need to create a new database for your table which can be done with these simple steps:
1. Open your SQL Management.
2. On the Databases Right Click on the Databases.
3. Name and Create a new Database where you will create your table.
4. After creating the database, click the "+" sign at the side of your database.
5. On the Tables Folder, Right click on it and Create New Table.
6. After defining every column of your table, Press Ctrl+s to save your table.
