Hall Allen
80 points
Posted on - 10/20/2012
Hi Experts,
While extracting a file through WinRAR I received an error message. It stopped working throwing a warning message i.e.
No archives found, as it is unknown to the application. If you have any idea for the warning, please help.
Thanks in advance.
WinRAR: Diagnostic messages
Warning
No archives found
You are probably having this error because:
1. You are using an unregistered trial version of WinRAR and your trial period is over.
2. You have two several versions of WinRAR.
To purchase WinRAR, follow these steps:
1. Open WinRAR.
2. Click "About" on the top menu bar.
3. Click "Purchase"
OR, you can try 7Zip. 7Zip is an excellent unzipper that supports almost any file type like RAR, ISO, ZIP, etc. And its FREE!!!
Get it from here:Â http://www.7-zip.org/
Hi
I will help you to solve your Winrar problem. The no archive found problem happens sometimes when the archive is corrupt or you have .rxx formats. Other wise, open Winrar and then navigate to the archive and extract. It will work for sure. If this does not work, then try other archive managers.
