While Installing Many Applications, I Face A 0x0000271d Error Message
What is the 0x00000271d error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
When the registry files are corrupted, then the system throws an error, which is known as 0x0000271d error, and this error can be taken seriously because it can arise from various other problems like hard disk failure and a lot of others. SmartPCFixer is the software that can be used to fix this error easily. The various others step to troubleshoot this error is to install repair tools and scan the system then fix all the problem which have come in the scans.
The steps to fix the error are as follows:
• Boot into the good configuration.
Step 1: Restart the system and press F8 repeatedly
Step 2: Startup Option Screen will appear and select the last good configuration.
• Uninstall previously installed driver or software.
• Run system restore
• Clean boot.
Step 1: Click on Start and type “MSConfig” in the search box and press Enter.
Step 2: Go to General and check Selective Startup.
Step 3: Uncheck Load startup items.
Step 4: Go to Services.
Step 5: Check Hide all Microsoft services.
Step 6: Click Disable all and click on OK then restart your computer.
• Run the DISM command.
• Reset.
