While installing Paragon Migrate OS to SSD 2.0 I received error message
While installing Paragon Migrate OS to SSD 2.0 I received the error message.
The screenshot of the message is given below. How can I get a remedy for this issue?
Please help.
Paragon Migrate OS to SSD – InstallShield Wizard
Error 1901. Error attempting to read from the source installation database: CWindowsInstaller4c2aebe4.msi.
Best Answer by Nicke Baker
Answered By 0 points N/A #147709
Hello Dibri,
You may be getting that error due to a recent hardware or software change. To fix the problem, you will need to do the following;
  • You will need to insert your Windows installation disc and then restart the computer.
  • After that choose your language settings and then click "next".
  • After that click "repair your computer".
Nicke
Answered By 0 points N/A #197186
Hello Dibri Avery
If you read the directory path of missing file then you will realize that installation process  requires installer file in .msi extension.
But the file does not exist.
This may be due to corrupted installer. Try updating your installer by visiting microsoft website if using windows operating system.
Regards
Richardd Wyatt
Answered By 60 points N/A #147710
Wow, guys! Your suggestions are superb and thanks for the invaluable information. Nicke Baker, your solution is very easy to do and works like a magic. Following your step-by-step system, I am now able to remove this problem. As a result, I am not encountering any problems anymore. Again, Nicke Baker, I am very happy with your solution. Thanks, friend.
