I need you help please, while installing SW 2011 I encountered error 1933. I have Windows XP 32 bit Operating System and from MS support this is a Windows file protection error, I guess windows will not allow changing some .dll files. However, even after installing higher Internet Information Servers I still have the same problem. Can someone please help?
SolidWorks Installation Manager
Error 1933. This setup requires Internet Information Server 4.0 or
higher for configuring IIS Virtual Roots. Please make sure that you
have IIS 4.0 or higher.
If the installation fails, contact Technical Support.
If you continue, you may encounter further errors. If you contact
Technical Support, be prepared to provide the installation log files
available in this directory.
Continue Installation Cancel Installation
While installing SW 2011 I have encountered error 1933
Hi Renato,
That might be an issue with the olepro32.dll file, but you should check the verbose install log just to confirm.
If it is indeed an issue with the olepro32.dll file, such as the file is missing or it is the incorrect version, you can remedy this by copying this file from another system where the setup is working. Save this file onto your system in the proper folder – by default it should be c:windowssystem32olepro32.dll – and register the file using the command prompt. Try running the installation again.
I hope this helps.
Katelynn
This is the Microsoft error. It may appear if SW 20011 that you are trying to install involves functions that the windows XP does not allow. Try to install it using the following steps:-
1. Open the installation wizard
2. Select “Customize” option
3. Choose the folder where you want to save it and click Next
4. Click on “not available” and then next
Hope it will help.
Laz Zebbena
