While installing WIS 09/2010 I received an error message
Hi guys,
While installing WIS 09/2010 I received an error message. The screenshot of the error message is as under. I clicked retry several times but no result. I do not know any possible reason behind the issue. How can I get a remedy of this issue? Please help.
Thanks in advance.
Error :
EWA Admin Tool
The required database files could not be added to the system (Error Code 50). Please check if the correct media is inserted and readable.
Do you want to retry?
