While Opening My System, I Face 0x0000185 Windows 10 Error Message
What is the 0x0000185 Windows 10 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
When the system isn’t connected or can’t be assessed during the start-up screen on Windows and stop the booting sequence from completing, then the critical error id known as 0x0000185 Windows 10 error. The cause of 0x0000185 Windows 10 error is the Kernel sub-system issue, Corrupted BCD data, Recent OS change, and System File corruption.
The steps to fix the error are described below:
• Using Automated Repair.
• Rebuilding the BCD data.
Step 1: Download Easy Recovery Essentials.
Step 2: Burn the image.
Step 3: Boot your system.
Step 4: Once the application is running, choose the “Automated Repair” and click on continue.
Step 5: Now a list of OS will come and you have to choose the drive which you are trying to repair.
Step 6: Now the error will be located and destroyed by the application.
• Using System Restore.
• Performing a repair or clean install.
