While running aktivix.org it has encountered a problem saying Secure Connection Failed.
Hi Expert,
While running aktivix.org it has encountered a problem saying Secure Connection Failed. It also says “The certificate is not trusted because the issuer certificate is not trusted. (Error code:sec_error_untrusted_ issuer)”. More details is at the screenshot. Please guide me to do the needful.
Thanks in advance.
En.wiki.aktivix.org uses an invalid security certificate.
Tile certificate is not trusted because it is self signed.
(Error code: (sec_error_untrusted_issuer)
• This could be a problem with the servers configuration. or it could be someone trying to impersonate the several.
• if you have connected to this server successfully an the past, the error may be temporary, and you can try again later.
