While Sending The Mails, I Face A 0x00002af9 Error Message
What is the 0x00002af9 error? Describe the cause of the error and explain various steps to fix the error and also attach a snapshot of the error.
When the hostname for the SMTP email server is not valid, then an error occurs, which is known as 0x00002af9 error. Basically, it is a “HOST not found” error message. When the sender uses directly the actual IP address, then the IP address is invalid. The error can also occur when the system installs or uninstall the application.
The steps to overcome 0x00002af9 error is as follows:
• Run SFC.
• Scan the system with error fixer and fix the issues which come during the scan.
To get effective software to fix this error, the user can also visit exsupport.org. The snapshot of the error is shown below:
Notifications
