Dibri Avery
60 points
Posted on - 09/26/2012
While trying CS 5 application I received the error message.
The screenshot of the message is as under.
If you have any idea regarding the issue, please help.
Thanks in advance.
License Expired
Licensing for this product has expired.
While trying CS5 application I received the error message
Your license for the product of Adobe Photoshop has expired. you need to renew your license or buy a new one. Most product keys for adobe has 1 year subscription so if you are using Adobe Photoshop for almost 1 year you need to buy renew or buy a new license.
Hi Dibri,
This error message signifies that your license for the software has expired or has reached the end period of it's term. That is, the term period for your license of the software has expired. You may have to renew the license or you may have to buy a new one.
Drianna allen
Thanks to both of you for helping me by giving me advice. Lgoy Budion, your solution makes me realize why this problem is going on. You are right. I am using this software for almost 1 year now. Following your advice, I have renewed the license and after that, the problem disappeared. You provided me with a very helpful solution, my friend.
