Hi guys,
While upgrading my Desktop Widget I received the fatal error message as under. I do not understand the message. But I am anxious about the message. What does it mean? If you have any idea for the error message please help me.
Thanks in advance.
Met Office Desktop Widget
Sorry, an error has occurred.
An error occurred while updating the application. Try updating it again.
If the problem persists, contact the application author.
I have read your problem. It is an error ,may be which widget you are using and you want to update that is unavailable in ms office. or the new updated version of that widget is not compatible with you OS registry system . So be sure about those thing and then try again .
Hope you will get the solution
Hi Jhon,
Seems like there is something on your computer (component or antivirus software) interfering with the process. You can try to disable start up programs under the task manager then restart the computer and try to update again. If it fails you can try to update the program on a new windows user. Make sure that you lower down the protection settings of your anti virus while doing the update, since updating is constant exchange of data incoming and outgoing your anti virus might detect suspicious files that’s why it blocks them or temporarily quarantine them.
