While using Excel it experienced a serious problem
My warm greetings to all,
While I am at work using Microsoft Excel to do my accounting task, an error message appeared on my screen while I am using some add-in, please see below the error message screen shot.
Microsoft Office Excel
Excel experienced a serious problem with the ‘microsoft office live add-in’add-in. If you have seen this message multiple times, you should disable this add-in and check to see if an update is available. Do you want to disable this add-in?
Yes No
As I am looking at the error message, my understanding on the error is about the add-in that I installed. I already removed all the add-in and installed it back because I can't accomplish my task without those add-ins.
Please extend your helping hand on this problem that I met. Looking forward to hear from you soon. Thanks.
