Who can describe about Android mini PC?
I am wondering what this Android Mini PC is about?
Why is it called Android Mini PC and difference from the others?
Dear Clarence,
Android mini PC is actually a device slighter larger than a USB thumb drive. It is inside a 3.5 inch plastic case. It has single-core 1.5GHz, 4GB internal storage, 512MB RAM. There is an HDMI port on the exterior which allows users to plug the computer into a television. Its resolution is at 1080p and is said to be capable of playing high-definition video. This mini PC also includes full size USB port with capability of input devices, micro USB port, microSD slot, Wi-Fi antenna. Mouse and key boards can be used in USB ports. This computer is capable of running android 4.0
Thanks,
An Android Mini PC is a “PC-on-a-stick”. It is based on an ARM design consist of an ARM V7-based 1 GHz Cortex-A8 processor, Wi-Fi 802.11 b/g/n, Mali-400 MP GPU, and VPU CedarX able to display 1080p video created by Rikomagic, a Chinese company, using AllWinner A1X SoC. The first and original model is Android Mini PC MK802 released in the market in May 2012.
It is capable of converting a display using an HDMI or DVI-D port into an Android computer. After the original model was presented, 5 other related models were released.
All models look very similar to a USB flash drive though a bit larger. It encloses a processor, storage, RAM, and Input/Output ports.
Notifications
