Everyone knows the free bulk mail. But this is a great problem for me that some free bulk emailers mails me every. So this is boring for me. Now I want to escape from them. What is the way to escape  free bulk emailers?
Who can give me a solution for free bulk e-mailers?
Wassup Danield, I believe I can be able to help you solve this problem since it has been experienced several times before. What you need to do to solve this issue is to unsubscribe from the mailing list in the emails or if that doesn't really help, then you can try downloading a software for filtering the emails.
You can look for a software as the 'Ass maker-email address encoding tool' This tool works in such a way that it encodes mail.to links in javascript so that your email address is hidden from other emails and therefore the harvesting robots cannot collect your emails.
You will be able to download the software from the link; http://www.sintraweb.pt/Public_files/assmkr31.zip
You can follow the prompts and install then restart your system for the software to work effectively
You can then run the software and ensure that it works well by inputting your address and put a default subject, cc header or message body. The software will construct a javascript code.
I hope this solves your query
Thanks
