Who makes the fastest laptop
Hello
I am always gaming and I need a fast laptop. Does anyone know who makes the fastest laptop for gaming
Thank you
Hello
Thank you
Dear Chris,
It's critically acclaimed that the best gaming oriented laptops out there are made by Alienware. They combine the power of a desktop PC and the portability of a laptop. They have the latest generation graphics processor and 3rd Generation Intel processors. You won't go wrong with the configuration they currently posses.
That doesn't mean they come cheap. They come in 3 categories: M14x, M17x and M18x; the later being a true power horse, mimicking desktop performance by far. They go from $1100 to $2000 leaving your wallet thinking if it was worth the buy. But you'll soon find out what comes underneath the hood.
The truth is they aren't very portable, but you wouldn't carry it into a Cafe anyway. They're there for LAN parties and similar things.
If you seek more information you should take a look on: http://www.alienware.com/Landings/laptops.aspx
I hope this helps.
I am also a gamer. So I know which laptop will preferable for you. You can buy M-Tech Laptops which one is the world best and fastest gaming laptop. It is very high quality laptop that was produced by M – Tech companies. M-Tech laptops was produced only for gaming. So you can buy it and enjoy the games.
Dear Chris J Curry,
The Alienware brand laptop is fastest laptop for gaming. For the past 15 years the folks at Alienware have been churning out high end gaming systems, and thankfully they continue to so. The M18x eclipse last year's Alienware M17x as their Editor's Choice among cost no object (over $3,000) gaming laptops.
Given below some configuration of Alienware brand laptop:
Name | Processor | Graphics chipset |
PCMark 7 Default |
Mobile Mark 2007 hr:min |
Alienware M18x |
Intel Core i7-2960XM (2.7GHz) |
Nvidia GeForce GTX 580M SLI |
3,333 |
1:38 |
Asus G74SX-A2 |
Intel Core i7-2630QM (2.0GHz) |
Nvidia GeForce GTX 560M (3GB) |
3,941 | 2:59 |
AVADirect Clevo X7200 |
Intel Core i7-980X (3.33GHz) |
Nvidia GeForce GTX 480M SLI |
N/A | 0.38 |
Alienware M17x(Sandy Bridge) |
Intel Core i7-2720QM (2.2GHz) |
AMD Randeon HD 6970M |
N/A | 2:24 |
Asus G74SX-BBK7 |
Nvidia GeForce GTX 560M (2GB) |
2,569 | 1:57 |
I hope that you will get your answer.
Thank you
Notifications
