avah.hannah
30 points
Posted on - 06/07/2012
Confused over which one to buy – iPhone or Android?
Both clearly have advantages over the other.
While I want an iPhone because of its vast number of applications ready in its library, it is designed to be technically Flash free.
Is the new model manufactured to keep off the "Adobe Flash plug-in required" error?
Who is ruling the mobile world?
Distinguishing between an android phone and an iphone may deem difficult as they look very similar. However if you look carefully you will notice the difference especially on the hardware. However it is established that iphone might be the best option for anyone as it is most preferred. Concerning the question of the new make, it cannot be said with certainty but it is always possible to download an adobe flash plug in on your iphone. There are many ways to go around it. There are many videos that can show you how to go around it. Go to:
https://www.youtube.com/watch?v=zf2l9FRWffI
