WhoisThisDomain 1.76- reliable for finding information?
Is WhoisThisDomain 1.76 reliable for finding information about a registered domain?
How about country code handling?
Hi!
With regards to the Who Is Domain 1.76, you can generally depend on its reliability. When searching for a registered domain name, the location of the domain name as well as its country code. The Who Is Domain 1.76 is a domain registration lookup utility. Â You can easily search for related info of the domain. For you to install the system,there is a system requirement to have Windows (any version).
From Windows 2000 to Windows 7, an internet connection and allowing outgoing connections from port 43.
I think you are using the older version of the program. I’m not sure if this is the latest version but I was able to find WhoisThisDomain v1.87 which can be downloaded from NirSoft | WhoisThisDomain v1.87. The WhoisThisDomain utility allows you to easily get information about a registered domain.
It is a domain registration lookup utility program that automatically connects to the right WHOIS server according to the top-level domain name, and retrieves the WHOIS record of the domain. This supports both generic and country code domains. This version works on any versions of Microsoft Windows from Windows 2000 up to Windows 8. To use the program, you need to allow outgoing connections to port 43.
To learn more about the application, you may visit the link above.
