How to manage the servers through the AD Management Tools Windows 7? How are the logs helpful in solving the problems with the Windows Servers in the Active Directory Management tools?
Why AD Management Tools For Windows 7 Is Usefull Of Active Directory
To deal with your servers, you initially need to coordinate your parts with your introduced highlights. For instance, to deal with a DHCP server, you need that component empowered in Remote Server Administration Tools. Once arranged accurately, you can then oversee parts, (for example, a DHCP server, or AD) and components, (for example, a WINS server) or any other server that is accessible to you. The DHCP part comfort, where you can then right tap on the DHCP symbol, and interface with the server.
![](https://www.techyv.com/sites/default/filesx2/users/Bhargav/DHCP.PNG)
You can likewise associate and deal with your servers to investigate them. Logs are useful, essentially dispatch the Event Viewer and take the same strides. Right tap the Event Viewer symbol and interface with the server in which you need to view sign on.
