I can play Warcraft 3 for as long as I want but after exiting the game it always gives me this fatal error that I don't know how to fix. I could still relaunch it and play without any problems but this error is annoying and it always pops out after quitting the game.
War 3
This application has encountered a critical error:
FATAL ERROR!
Program: G:GamesWarcraft IIIWar3.exe
Exception: 0xC000000005 (ACCESS_VIOLATION) at 001B:6F09844E
The instruction at '0x6F09844E' referenced memory at '0x000000008'.
The memory could not be 'read'.
Press OK to terminate the application.
Why am I getting this error whenever I quit Warcraft 3?
The error says that there is a particular address in the memory where an instruction is loaded and is already not accessible. This is common to old RAM memory cards. You can still do your computing habits but if an instruction is loaded to a particular region in the memory or in a particular memory address, the program would launch an error message displaying the memory address where the error occurred.
The computer doesn’t have any problem loading and accessing the program in the memory because there is a page file where the entire load is being shared to have a balance in the total load of the memory. But when you close the application, it cannot free up the memory of the loaded data that’s why it displays an error.
It encounters error when removing the loaded data in a particular memory address.
Replacing the memory card would solve this problem.
