wirt yule
50 points
Posted on - 02/05/2013
I use Power DVD 11 on my pc which runs on Windows 7 32 bit. I recently updated power dvd 11 to build 2408. Now, when launching the application, I'm having c++ runtime error. Is there a patch for Powerdvd 11 c error?
Why am I having Powerdvd 11 c error?
Hi Curtis, this error can be caused by two factors-
1. A runtime component of C++ is missing.
2. Software problem.
If the problem is caused by the first reason then you can update the C++ component library.
The link is After updating this if the problem exists then you can reinstall your software and try again.
I hope this will work.
Thank you.
I recommend you that you have the latest windows updates and Please make sure to have installed the latest Power DVD 11 Patch then and if the problem is appearing again check your problem again.
1. Unrar the file.Â
4. Start installation. Â Â
Run the registry cleaner and your issue must be fixed.
