Why am I not able to format my pen drive?
I use a pen drive of Kingston brand. It used to work fine but one day it got infected by virus. Since that day I am not able to format my pen drive. Is there any way to format the pen drive?
Hey Henry Klein!
There are many software that can be used to format the USB. Same was mine problem. I was unable to format my USB due to viruses and I was badly stuck in this situation. I tried to format it in my friend's computer but I found myself with no luck.
Then I tried some softwares. The best software, I found to format my USB was HP USB stick Storage Format Tool. I was succeeded in formatting my USB with this software. I would like to recommend you to use same software. It will also help you.
I am going to add a link here:
http://files.extremeoverclocking.com/file.php?f=197
You can download the software from this link and format your USB.
Hi there,Â
It seems you are trouble with Viruses.
Follow my steps : –Â
I am now able to format my pen drive because of these 2 experts who helped give their solutions and thank you also to techyv very good job you make for the people who have problems in computer, it really helps to all of people who are having problems with the computer, i salute to both of you guys, keep it up.
